Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Constant Toolpath generation
ICanSpinIt
ICanSpinIt
There was an update a long time ago where the Toolpaths would start automatically regenerating if one operation was changed. It started bogging down the computer. I dealt with it until now! I have about 100 operations that are trying to regenerate if I make a change to 1. Its freezing everything up.
I have unchecked both of the boxes in the prompts under the manufacturing settings. It still goes crazy
How do I get this auto generate issue to stop?
Tom.Hemans
Hi @ICanSpinIt,
You can Protect toolpaths (right click on the toolpath in the Browser and select Protect) to stop it from being recalculated.
Hope this helps,
Tom
Tom Hemans
Technical Consultant
HughesTooling
Have you disabled in process stock generation?
Mark Hughes
Owner, Hughes Tooling
ICanSpinIt
The tool paths were all locked and it would still re-generate. The answer below solved the issue. Thank you for replying
ICanSpinIt
Took me about 10 minutes for the computer to allow me to un-check it, but that solved the issue. I have a fast computer again!! Thank you
