confused by "lifting feed plane to topmost ramp" warning
rumpelstielz
rumpelstielz
i get this warning a lot and am not understanding the logic. Here's an example:
Screen Shot 2018-02-11 at 12.54.22.pngScreen Shot 2018-02-11 at 12.57.32.pngScreen Shot 2018-02-11 at 12.54.37.png
it looks to me as if the topmost ramp is starting at 0.2mm above the part/stocktop, so a feed plane 1mm above the part should do ?
GENERAL DISCLAIMER: if there isn't a file attached to my posts then there is a reason for it. wherever i can i will attach a file for troubleshooting.If no file is attached i will always try to explain as clearly as possible with illustrative screenshots. when i have an issue that can only be helped by attaching a file which i cannot share publicly i won't ask about it here.
Steinwerks
I agree it looks like it should be fine. Can you share your part or recreate with the same values in a dummy part and attach it here?
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
rumpelstielz
@Steinwerks can't share the file but it's easy and quick to test: create a 1.5mm extrusion or cube, run a contour and put settings as shown above ... the warning message will ensue
Steinwerks
Well the setting to fix it is not in your screenshot!
Change your Safe Distance on the Linking tab to .2mm.
Edit: really it should only have to be whatever your Clearance height is, so 1mm will also get rid of the error.
Neal Stein
Find me on:
