@Anonymous
That is code you have generated at your end, there are no -X or -Y values in the code that I generate here.
Attached is the full .txt file for the complete program, here are the same lines (My sequence numbers are slightly different as they don`t do the first 3 comment lines), there are no negative values as there are in yours.
N202 1.2531, 10.6000,-1, 20, 0, 0.9000, 10.6000
N203 1.1531, 10.6000, 0, 20, 0
N204 1.1531, 10.6000, 0, 0, 0
N205 1.8431, 10.6000, 0, 0, 0
N206 1.9431, 10.6000, 0, 40, 0
N207 1.7900, 10.7531,-1, 40, 0, 1.7900, 10.6000
N208 1.6369, 10.6000,-1, 40, 0, 1.7900, 10.6000
N209 1.7900, 10.4469,-1, 40, 0, 1.7900, 10.6000
N210 1.9431, 10.6000,-1, 40, 0, 1.7900, 10.6000
N211 1.8431, 10.6000, 0, 40, 0
N212 1.8431, 10.6000, 0, 0, 0
N213 0.9806, 11.2670, 0, 0, 0
N214 0.9686, 11.1677, 0, 60, 0
N215 1.1070, 11.1331, 1, 60, 0, 0.9000, 10.6000
N216 1.8421, 10.9278, 0, 60, 0
N217 2.1178, 10.5479, 1, 60, 0, 1.7900, 10.6000
N218 1.8421, 10.2722, 1, 60, 0, 1.7900, 10.6000
N219 1.1070, 10.0669, 0, 60, 0
N220 0.3669, 10.3930, 1, 60, 0, 0.9000, 10.6000
N221 0.3281, 10.6000, 1, 60, 0, 0.9000, 10.6000
N222 0.8949, 11.1719, 1, 60, 0, 0.9000, 10.6000
N223 0.8940, 11.2718, 0, 60, 0
N224 0.8940, 11.2718, 0, 0, 0
N225 2.9469, 11.3286, 0, 0, 0
N226 2.8469, 11.3286, 0, 20, 0
N227 3.2000, 10.9754,-1, 20, 0, 3.2000, 11.3286
N228 3.5531, 11.3286,-1, 20, 0, 3.2000, 11.3286
N229 3.2000, 11.6817,-1, 20, 0, 3.2000, 11.3286
N230 2.8469, 11.3286,-1, 20, 0, 3.2000, 11.3286
N231 2.9469, 11.3286, 0, 20, 0
N232 2.9469, 11.3286, 0, 0, 0
N233 2.2569, 11.3286, 0, 0, 0
N234 2.1569, 11.3286, 0, 40, 0
N235 2.3100, 11.1754,-1, 40, 0, 2.3100, 11.3286
N236 2.4631, 11.3286,-1, 40, 0, 2.3100, 11.3286
N237 2.3100, 11.4817,-1, 40, 0, 2.3100, 11.3286
Must be either the Post Processor you are using, are you using the latest Flowmaster PP ??
Like I said, it is OK here as far as I can tell 🙂
Regards
Ro
