Component Pattern in 2D Cutting - Wrong setting or bug?
Message 1 of 14
I've created a component pattern that contains 3 different 2d cutting profiles.  Simulation shows correct.  My output file goes to hell after the first vertical row of components finishes.  At this point the object is orientated differently.  Now after completing each 2d profile, its inserting a negative coordinate set causing a huge travel move, then returning to the correct coordinate to perform the next 2d cutting profile.  Simulation doesn't show these moves.
Screenshot 2 shows fusions travel moves.
20191115_132634.jpg shows how the file is processed w/ the negative coordinates inserted
abs 502.txt is the generated file.   Line 234 is where it starts to bomb out
https://a360.co/2OeljNz      Shared file
Any ideas on this behavior?
Thanks!
Replies (13)
Message 2 of 14
engineguy
@Anonymous
I think it may be your setting of the start point, start should be at the WCS using the Flowmaster PP, I tried changing the order and starting at the WCS using the Flowmaster PP and I couldn`t find any -X or -Y values, with your start point there are lots of -X and -Y values scattered around 🙂 🙂
Start @ WCS pointStart @ WCS point
Anyway, try the attached file, might be of some help 🙂 🙂
Regards
Rob
Message 3 of 14
I appreciate the help.   Your file does the same thing.  Looks like it does the first 7 in the order you changed, then goes to hell again w/ the negative coordinates.   If you look at the output file, around line 227- it starts creating the negative value in an extra coordinate line above the correct coordinate.  Does this function have some unique callout I need to account for in my post processor?  This is for a Flow Waterjet if you're curious.
line 205-242
1.2531, 10.6000, 0, 20, 0
1.1531, 10.6000, 0, 0, 0
1.8431, 10.6000, 0, 0, 0
1.8431, 10.6000, 0, 40, 0
1.9431, 10.6000,-1, 40, 0, 1.7900, 10.6000
1.7900, 10.7531,-1, 40, 0, 1.7900, 10.6000
1.6369, 10.6000,-1, 40, 0, 1.7900, 10.6000
1.7900, 10.4469,-1, 40, 0, 1.7900, 10.6000
1.9431, 10.6000, 0, 40, 0
0.9806, 11.2670, 0, 0, 0
0.9806, 11.2670, 0, 60, 0
0.9686, 11.1677, 1, 60, 0, 0.9000, 10.6000
1.1070, 11.1331, 0, 60, 0
1.8421, 10.9278, 1, 60, 0, 1.7900, 10.6000
2.1178, 10.5479, 1, 60, 0, 1.7900, 10.6000
1.8421, 10.2722, 0, 60, 0
1.1070, 10.0669, 1, 60, 0, 0.9000, 10.6000
0.3669, 10.3930, 1, 60, 0, 0.9000, 10.6000
0.3281, 10.6000, 1, 60, 0, 0.9000, 10.6000
0.8949, 11.1719, 0, 60, 0
0.8940, 11.2718, 0, 0, 0
-2.9469, -11.3286, 0, 0, 0
2.9469, 11.3286, 0, 0, 0
2.9469, 11.3286, 0, 20, 0
2.8469, 11.3286,-1, 20, 0, 3.2000, 11.3286
3.2000, 10.9754,-1, 20, 0, 3.2000, 11.3286
3.5531, 11.3286,-1, 20, 0, 3.2000, 11.3286
3.2000, 11.6817,-1, 20, 0, 3.2000, 11.3286
2.8469, 11.3286, 0, 20, 0
-2.2569, -11.3286, 0, 0, 0
2.2569, 11.3286, 0, 0, 0
2.2569, 11.3286, 0, 40, 0
2.1569, 11.3286,-1, 40, 0, 2.3100, 11.3286
2.3100, 11.1754,-1, 40, 0, 2.3100, 11.3286
2.4631, 11.3286,-1, 40, 0, 2.3100, 11.3286
2.3100, 11.4817,-1, 40, 0, 2.3100, 11.3286
Message 4 of 14
Running dumper to see whats feeding my post processor file shows the negative values also-
>>> Pattern instances: 0,3,6,9,12,15,18,21,27,30,33,36,39,42,45,48,51,54,57,60,63,66,69,72,75,78,81,84,87,90,93,96,99,102,105,108,111,114,117,120,123,126,129,132,135,138,141,144,147,150,153
STATE position=[-0.89402, -11.271848, 0.6]
STATE power=OFF
STATE radiusCompensation=RADIUS_COMPENSATION_OFF // off
4867: onRapid(-2.9468749639556164, -11.328571725079394, 0.5999999909889041)
4868: onRapid(-2.9468749639556164, -11.328571725079394, 0)
4869: onPower(true)
4869: onCommand(COMMAND_POWER_ON)
4870: onParameter('action', 'pierce')
4871: onMovement(MOVEMENT_LEAD_IN /*lead in*/)
4871: onLinear(-2.8468750030036984, -11.328571725079394, 0, 39.370100366787646)
4872: onMovement(MOVEMENT_CUTTING /*cutting*/)
4872: onCircular(false, -3.1999999519408218, -11.328571725079394, 0, -2.8468750030036984, -11.328571725079394, 0, 39.370100366787646)
direction: CCW
sweep: 360deg
normal: X=0 Y=0 Z=1 (XY)
radius: 0.353125
Message 5 of 14
engineguy
@Anonymous
That is code you have generated at your end, there are no -X or -Y values in the code that I generate here.
Attached is the full .txt file for the complete program, here are the same lines (My sequence numbers are slightly different as they don`t do the first 3 comment lines),  there are no negative values as there are in yours.
N202 1.2531, 10.6000,-1, 20, 0, 0.9000, 10.6000
N203 1.1531, 10.6000, 0, 20, 0
N204 1.1531, 10.6000, 0, 0, 0
N205 1.8431, 10.6000, 0, 0, 0
N206 1.9431, 10.6000, 0, 40, 0
N207 1.7900, 10.7531,-1, 40, 0, 1.7900, 10.6000
N208 1.6369, 10.6000,-1, 40, 0, 1.7900, 10.6000
N209 1.7900, 10.4469,-1, 40, 0, 1.7900, 10.6000
N210 1.9431, 10.6000,-1, 40, 0, 1.7900, 10.6000
N211 1.8431, 10.6000, 0, 40, 0
N212 1.8431, 10.6000, 0, 0, 0
N213 0.9806, 11.2670, 0, 0, 0
N214 0.9686, 11.1677, 0, 60, 0
N215 1.1070, 11.1331, 1, 60, 0, 0.9000, 10.6000
N216 1.8421, 10.9278, 0, 60, 0
N217 2.1178, 10.5479, 1, 60, 0, 1.7900, 10.6000
N218 1.8421, 10.2722, 1, 60, 0, 1.7900, 10.6000
N219 1.1070, 10.0669, 0, 60, 0
N220 0.3669, 10.3930, 1, 60, 0, 0.9000, 10.6000
N221 0.3281, 10.6000, 1, 60, 0, 0.9000, 10.6000
N222 0.8949, 11.1719, 1, 60, 0, 0.9000, 10.6000
N223 0.8940, 11.2718, 0, 60, 0
N224 0.8940, 11.2718, 0, 0, 0
N225 2.9469, 11.3286, 0, 0, 0
N226 2.8469, 11.3286, 0, 20, 0
N227 3.2000, 10.9754,-1, 20, 0, 3.2000, 11.3286
N228 3.5531, 11.3286,-1, 20, 0, 3.2000, 11.3286
N229 3.2000, 11.6817,-1, 20, 0, 3.2000, 11.3286
N230 2.8469, 11.3286,-1, 20, 0, 3.2000, 11.3286
N231 2.9469, 11.3286, 0, 20, 0
N232 2.9469, 11.3286, 0, 0, 0
N233 2.2569, 11.3286, 0, 0, 0
N234 2.1569, 11.3286, 0, 40, 0
N235 2.3100, 11.1754,-1, 40, 0, 2.3100, 11.3286
N236 2.4631, 11.3286,-1, 40, 0, 2.3100, 11.3286
N237 2.3100, 11.4817,-1, 40, 0, 2.3100, 11.3286
Must be either the Post Processor you are using, are you using the latest Flowmaster PP ??
Like I said, it is OK here as far as I can tell 🙂
Regards
Ro
Message 6 of 14
Can you attach the dumper/dump file from the installed post library.  I'm generating off your file.  Our dump post should match.
Thanks!
Message 7 of 14
engineguy
@Anonymous
Have you tried the complete code I uploaded ? If that runs then it is probably the PP you are using, I have the latest one from Sept 2019.
Regards
Rob
Message 8 of 14
engineguy
@Anonymous
Dan
Here is the same section from my dump post :-
STATE power=OFF
4869: onPower(true)
direction: CCW
sweep: 360deg
radius: 0.353125
Regards
Rob
Message 9 of 14
" I have the latest one from Sept 2019."
Are you referring to the current Flow Post Processor ? -
Copyright (C) 2012-2018 by Autodesk, Inc.
All rights reserved.
Flow waterjet post processor configuration.
$Revision: 42473 905303e8374380273c82d214b32b7e80091ba92e $
$Date: 2019-09-04 07:46:02 $
FORKID {F61954EF-5A29-4B93-93E7-870BC2786880}
Message 10 of 14
engineguy
@Anonymous
Yep, that would be this one 🙂
description = "Flow Waterjet ORD";
vendor = "Flow";
vendorUrl = "http://www.flowwaterjet.com";
legal = "Copyright (C) 2012-2018 by Autodesk, Inc.";
certificationLevel = 2;
minimumRevision = 39000;
Regards
Rob
Message 11 of 14
Unless you are aware of something i'm not, every one of those Flow waterjet post processors autodesk has been posting are junk.   You can tell by the 1st line.   There are two sets of numbers representing lines and arcs.  If you add them up, the total should be 3 less than the total number lines of code.
// This file was created by FlowMaster(R), which is proprietary to Flow International Corporation. 1196 728
// Created by Autodesk HSM
There is 1459 lines of code in the file you posted.   For that PP to work, it needs to be-
// This file was created by FlowMaster(R), which is proprietary to Flow International Corporation. 728 728
Also your dump file shows the same negative values I'm getting in the pattern output section....  I see absolutely no reason why that should be in there.  Its the correct coordinate, just w/ a negative added to it.   I've cut 100's of files w/ my modified flow post.  This issue is 100% pattern related.
Any thoughts?   Thanks!
Message 12 of 14
engineguy
@Anonymous
Nope, no more ideas on this for now, the code generated here looked correct to me (I`m no expert on Waterjet) so I can only suggest you try loading the code to your machine and see if it will accept the program, you will probably have to change the extension fron .txt to .ord if your control doesn`t accept .txt files.
Regards
Rob
Message 13 of 14
So I think I know whats going on...  When using patterns, In the dump file "currentSection.workPlane=" changes when the pattern direction changes.  Thats screwing up all the coordinates making inverse values and completely swapping X & Y on the last row.
My PP is just reading the position coordinates.   I need to make it look at the "currentSection.workPlane="value, then read the current coordinates, apply the necessary changes, and write it.
Message 14 of 14
kyle.kershaw
@Anonymous is on track with the thought about the changing workplanes and the need to account for that difference.
For those wondering how, that's done, the setRotation(remaining) function is the key. 1st thing in the onSection entry point.
function onSection() {
var remaining = currentSection.workPlane;
if (!isSameDirection(remaining.forward, new Vector(0, 0, 1))) {
error(localize("Tool orientation is not supported."));
return;
setRotation(remaining);
If anyone is interested in testing, I have a potential replacement for the Flow post that needs some eyeballs and exercise. Private message me if you're interested
The post addresses some of the issues I've gleaned from the forum pages. Counters, duplicate lines, and arc formats.
Shout out to @Anonymous. I used his post to discover the arc output was all wrong in the stocker.
Kyle Kershaw
Technical Consultant
