Combine generative design with existing tooling
Is it possible when creating a generative design that one of the constraint is that the design/product or part has to be created with the existing tooling (say turn machines, CNC machines) and NOT with the 3D printer?
I_Forge_KC
While turning isn't current supported, most milling strategies are. As far as manufacturing constraints go there are 2, 2.5, 3, and 5 axis machining available. You also get to specify the minimum tool diameter, shoulder length, and head/collet diameter.
K. Cornett
Generative Design Consultant / Trainer
Thanks for the answer! That really helps. Do you have any idea if turning is going to be possible in the future?
I_Forge_KC
I honestly couldn't tell you. The primary concern has been traditional 2.5 and 3 axis machining as the go-to methods. I would say that you can probably get creative with the 2-axis solutions for turned parts and come out close-ish.
The other thing would be to divide up your cylindrical spaceclaim into X number of wedges and then use the frictionless constraint types to approximate symmetry lines. From there you can kind of get a profile that could be revolved.
K. Cornett
