Cloud posts not syncing with team
Billy.conturo
Message 1 of 38
Billy.conturo
I'm having some issues with this. From reading some other related posts I don't think I'm the only one. I tried a full restart of the system. My entire team is having this issue.
Replies (37)
Message 21 of 38
kencondal
Hi Jeff,
Here are the two most recent logs.
I still don't know how to execute the rescan command you mentioned.
Ken
Message 22 of 38
Billy.conturo
I'm not sure how to enter text commands in fusion. Is there a quick guide to doing that?
Message 23 of 38
jeff.pek
In the File dropdown, there's a View submenu. In that, you'll see "Show Text Commands". You can type in the text command in the lower (small) text area.
  Jeff
Message 24 of 38
jeff.pek
Thanks. I see other errors on your log, aside from the problem with the diagnostic logs.
Can you confirm that you have sufficient disk space on the drive that contains %localappdata%, and that you are able to create files in that area (manually)?
Jeff
Message 25 of 38
kencondal
Jeff,
The drive has over 64 GB of free space and yes, I just created a file there.
Is one of the other errors that Fusion keeps downloading the same update? I've gotten the May update at least 3 times and the June update twice (the second of which should be in those logs).
Ken
Message 26 of 38
Billy.conturo
I entered that command and now things seem to be updating on my machine. Will it stay that way or do I need to run it every time I want things to sync? When I run the command on a different machine I get this error
Traceback (most recent call last):
File "<string>", line 1, in <module>
NameError: name 'wipmds' is not defined
Message 27 of 38
jeff.pek
Hmmm. Might be worth posting specific posts about those problems in the Support forum, where others can hopefully chime in?
  Jeff
Message 28 of 38
balsmen
Hey @Billy.conturo,
In the text command panel on the computer you saw the problem for, on the bottom right of the panel you should see 3 radio buttons - one for "Txt", one for "Py", and one for "Js".
In order to run this specific text command, you need to make sure to have "Txt" enabled.
Noah
Noah Balsmeyer
Fusion Mfg Software Engineer
Message 29 of 38
Billy.conturo
Ah yes, of course. Sorry about that. I'm running around doing a thousand things today.
Message 30 of 38
Billy.conturo
@jeff.pek
Actually, the dropdown dialogue in the post config still isn't realizing I deleted files from the CAMposts assets. The text command seemed to have no effect.
Message 31 of 38
Billy.conturo
 to produce the problem:
close fusion
delete cache
delete contents of CAMposts assets folder in browser
open fusion
no posts in config dropdown
close fusion
upload a few posts in browser to CAMposts
open fusion
cache is created
posts listed in config dropdown
close fusion
delete all posts again for CAMposts assets folder in browser only
open fusion
posts still listed in config dropdown  <--- cache didn't update
So we are back where we started. To consolidate things I reposted my issue in this message with the step by step to produce the problem.
Message 32 of 38
jeff.pek
And, with this, running the "rescan" command still didn't help?
Can you send me a recent log file?
Thanks. I hope we're able to get to the bottom of this, and get a fix going.
Jeff
Message 33 of 38
Billy.conturo
correct, rescan didn't seem to do anything.
Message 34 of 38
kencondal
This bug just keeps getting worse! Now when I upload a CAM post to replace an existing one (same name) Fusion is still executing the old one. The list of CAM posts I'm seeing doesn't match what's in the Assets Folder - some are missing and others that were deleted days ago are still there.
I've reset my cache and run rescan and nothing seems to help.
Ken
Message 35 of 38
kencondal
After seeing these missing cloud posts on my two Win 10 machines, I just tried it on my MacBook Pro and it reports no cloud posts (there should be 4 of them). Everything else in the cloud - templates, tool libraries and projects are all fine. The assets folder and the web interface all list the posts but the CAM section doesn't see them or sees the wrong ones.
I really hope this gets fixed in the next release.
Message 36 of 38
Billy.conturo
I see the newest update fixed the syncing issue. Fantastic!!!
Message 37 of 38
kencondal
This is NOT solved with the latest update.
I'm still having the same problem with the CAM not seeing the correct cloud posts. I have 3 machines - 2 Win 10 and one MacBook. They all see different things in the cloud library and none of them are correct.
Message 38 of 38
Billy.conturo
Ya, I spoke too soon. It seemed to be working at first but now it's not. I'm going to have to put our posts on a google drive for now until it's worked out.
