Circular interpolation on num 760
bd.aurelien
bd.aurelien
I would like to use the generic num post for a milling part on a num 760 but I've got a problem with some G02 and G03. Sometimes Fusion 360 give me block like this:
G01 X79.311 Y-43.775 F117.
G03 Y-44.226 R0.319
G01 X90.482 Y-55.346
The coordinates is given only in one axis so my machine show me an error (101) because my cnc need coordinates in the two axis to make a circular motion.
So there is a way to force my post to give me G03 or 02 with full coordinates of the point ?
Arun.rs
@bd.aurelien
Thanks for raising your concern via Forum.
You can use the following command to force XYZ positions.Place this command to the 'onCircular' command.
forceXYZ();
From this :
case PLANE_XY:
      writeBlock(gPlaneModal.format(17), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), "R" + rFormat.format(r), conditional(isHelical(), "K" + xyzFormat.format(getHelicalPitch())), feedOutput.format(feed));
      break;
    case PLANE_ZX:
     writeBlock(gPlaneModal.format(18), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), "R" + rFormat.format(r), conditional(isHelical(), "J" + xyzFormat.format(getHelicalPitch())), feedOutput.format(feed));
     break;
    case PLANE_YZ:
     writeBlock(gPlaneModal.format(19), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), "R" + rFormat.format(r), conditional(isHelical(), "I" + xyzFormat.format(getHelicalPitch())), feedOutput.format(feed));
     break;
To This:
case PLANE_XY:
      forceXYZ();
      break;
    case PLANE_ZX:
      forceXYZ();
      break;
    case PLANE_YZ:
      forceXYZ();
      break;
Hop this helps !
If my post answers your question, please click the 'Accept Solution' button. This helps everyone find answers more quickly!
Arun.RS
Senior Technology Consultant
bd.aurelien
Ok It's wokrs for me
Thanks you very much
serge.quiblier
Hello @bd.aurelien
I am informing you we have made severals changes to the NUM post to fix potential issues.
One of them if the modality for XYZ, another one is a possible minus radii if we try to ouput an arc over 180 degree using R output instead of IJ.
It is updated in the library.
Have a nice day.
Regards.
Serge.Q
Technical Consultant
cam.autodesk.com
