- Mute
- Permalink
- Report
Good Morning,
Before I begin, I want to thank the many people on this forum who have taken the time to respond to my "beginner like" questions. When I discuss what I'm doing to others I always explain that I would not have gotten this far if it wasn't for the support I've received from this forum. So thank you very much, it's a great journey and learning is part of it.
Before I post a question, I always try to explore as much as I can in F360 and make every effort to exhaust the possibilities before I post. But I'm stumped once a gain.
I've enclosed a file of a part which should be a very simple operation. But I'm finding it very difficult to accomplish.
The ring you see has operations on both ends of the ring. The file you are looking at has two. I would like to surface clean the end. Then cut a 0.250"x0.375" channel.
I've set CAM to "surface" operation but I seem to be getting a zig zag operation which I don't want. I have tried many other settings but this is the only one that comes close. Is there a way to edit so that the cutting follows the circumference instead of zig zag?
I think the channel is ok but you may find fault with my approach. I want to learn to do this correctly so please, any comments will be helpful.
Thank you very much for any input
