- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I milled again a part I did in the past, 4 more times, but this time I need to make 2 and as I have a stock piece that perfectly fits 2 parts I copied my model and add the contours to existing operations.
What I noticed now, and didn't in the past models I milled, is that one internal contour is larger than it should be, I noticed first time when milling the interior chamfer, I didn't heard the tool touching the material, when it was finished I noticed there was no chamfer.
I flipped the part to Side B and milled the same contour and another larger one. when I removed the part from vise I noticed the contour on the bottom was smaller than the one I made from Side A. I measured the one on Side A and indeed it was larger than it should be, than I tried to find the issue, when I edited the operation I noticed the Tool #6 is 1mm diameter - I know for sure it was defined as 1.58mm.
I think Fusion is caching the tool diameter for each milling operation, instead of using the diameter set in TOOL LIBRARY, and if any change is made in the tool library, the settings are NOT applied until I select again the same tool, in my case it was tool #6, so until I click SELECT and chose again the same tool #6, I could still see the tool defined as 1mm when editing that specific operation.
Is this behavior normal ? Shouldn't Fusion fetch the diameter from the tool library when generating a new GCODE file?
I know it's not a good habit to use the same tool number for a different tool, but I only did it once, when I broke the 1mm endmill, I placed this 1/16" endmill in the same collet and set the new dimensions both in Fusion and in PathPilot, usually I define as a new tool .. but when I broke the 1mm tool, now a few weeks ago I didn't do that 😞
With the new models I made those weeks I didn't had this issue as I started with a new file every time, but in this case, I opened the model I created about a month ago and modified it to mill 2 parts in the same time.
PS. in the file attached, the operation named "2D interior Contour MUCH FASTER from 14min to 4min" in the first setup (the only operation not suppressed) is one that I did not modified yet, I will chose again the tool now to generate the correct toolpath this time, I will make the parts again now.
