changing location of m08 and m09 in fusion post for daewoo vmc fanuc oi-mb
egrimU4Y2L
egrimU4Y2L
I am currently trying to change the post processor placement of m08 and m09. Controller is fanuc oi-mb for a daewoo mill. I always want m08 to be on the line directly after the g43 Z2. line (since I always have the tool rapid down 2 inches above part for clearance height for every part I do) at the beginning of each tool.
To turn off the coolant at the end of each tool, I always want m09 on the same line with the g80.
I was wondering if somebody could help me with this or at least point me in the right direction?
I have attached an example post where I did the changes I want by hand. I have also attached the post processor I want modified.
Chris
KrupalVala
Hi @egrimU4Y2L ,
Please add setCoolant codes as shown below,
These codes help to turn-on coolant code if  drilling Heights are different.
if (isFirstCyclePoint() || isProbeOperation()) {
    if (!isProbeOperation()) {
      // return to initial Z which is clearance plane and set absolute mode
      repositionToCycleClearance(cycle, x, y, z);
    setCoolant(tool.coolant); // add coolant mode
Below codes will turn of coolant at the end of drilling cycle.
 if (!cycleExpanded) {
      writeBlock(gCycleModal.format(80),setCoolant(COOLANT_OFF));
      zOutput.reset();
Save the modified post and test the codes.
Krupal Vala
Senior Technology Consultant - Post Processor & Machine Simulation
Laurens-3DTechDraw
It seems the M08 is already in the correct place?
The M09 on the last G0 move is a little tricky. But right after it is easy.
Find an updated post attached.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
Found out the hard way is the best way to win.
