Change tool for multiple operations
djowen40
Message 1 of 14
djowen40
I use a machine that is for lack of a better words "communal" at a teaching institute. We generally have a standard set of tools but on occasion a tool is not available and I want to substitute the next best alternative from my library in. As far as i can tell the only way to swap out a tool is to edit each operation which seems slow.
Is there a way to change the tool for multiple operations?
I made a quick (one minute)  video to help illustrate. I realise the video only involves two ops which would be very fast to change but more ops means more changes etc. and it seems like an obvious function of the tool library.
Replies (13)
Message 2 of 14
HughesTooling
You could edit the tool in your document, editing the tool once it's in your document will not affect the tool in your library. It's a shame the tool is not available in compare and edit so you could select a different tool for a block of ops.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 3 of 14
djowen40
Agreed that is an option. But means manually editing it back if/when the desired tool becomes available. I have to admit I also expected to find it in compare and edit...
Would be nice to see tool swapping become an option but i suspect it is not a common problem for commercial operation.
Message 4 of 14
Compare and edit is simply missing the tool option. It is a not a feature request but an oversight.
Message 5 of 14
jacob_r_jennings
+1, this is tedious
Message 6 of 14
marcus.toepke
+1 Man we need this
Message 7 of 14
jeff.pek
Are you looking to change more than the tool number?
  Jeff
Message 8 of 14
marcus.toepke
Replace the tool in multiple Operations
As an example: You use hole recognition and this creates several operations, now I want to specify a countersink tool in several operations, for example, which should be the same for all operations ... I have to call up all operations individually and change the tool.
I know what you were getting at.
Change the corresponding tool in the tool list, but that would be an unprofessional solution!
Or another example, I use operation templates for different actions, now I want to use the same tools for all actions so that I don't need an unnecessary number of tools.
People have been asking for this feature for so long!
Message 9 of 14
jeff.pek
The reason I asked what I did is that it would be super-easy to allow Compare and Edit to show the tool number, so it could be changed for multiple operations. But, it gets more complicated if you want to fully replace the tool. I'm guessing that just changing the tool number is not sufficient, but wanted to check that.
Jeff
Message 10 of 14
rob.blanch
Drop down list in compare and edit that shows all tools already available for the current design would work, surely? They already have names/descriptions that are used when selecting a tool, not sure why selecting the tool number would be better, but anything functional would be welcome! Been waiting on this feature for years - changing the tool on 50+ operations at a time is more than tedious :). It seems like it would be easy to implement, but perhaps there is something I am missing...
Message 11 of 14
endurance_aw
Any idea, if this has been sorted?. I have 70+ operations to change tools for
Message 12 of 14
marcus.toepke
A horror work around is, to edit the tool that you want to change to the tool that you need in your actual document.
But it is really poor solution and only if you don't need the tool in other operations.
@jeff.pek  this problem is from 2018 here in forums or is there another solution?
Message 13 of 14
seth.madore
No, there is no other solution at present
Seth Madore
Message 14 of 14
a.laasW8M6T
This is still not a great solution, but better than opening each toolpath and selecting the new tool
(view in My Videos)
Andrew Laas
Senior Machinist, Scott Automation
