Change to M4 as default setting
Carbidecnc
Message 1 of 27
Carbidecnc
Does anyone know how to change M3 rotation on a lathe spindle to m4 as the deafault in fusion,so when I post process it will always be M4 ccw as my tooling is on the opposite side I need my lathe to spin ccw
Accepted solutions (3)
Replies (26)
Message 2 of 27
ivan.stanojevic
When you define your tool uncheck clockwise option
Ivan Stanojevic
Message 3 of 27
Carbidecnc
Ok that changes it to M4 but my tool is facing the wrong way now in the cam environment,previously the orientation was right
Message 4 of 27
Carbidecnc
Ok just figured it out seen the orientation in turret bit thanx for the help
Message 5 of 27
Carbidecnc
Another problem how do I get the blue line down to the tip if I've flipped the tool in the tool setup page it doesn't seem to line up with my profile geometry
Message 6 of 27
ivan.stanojevic
I am not really sure what kind of problem you have.
Could you please upload some screenshots or record a screencast?
Ivan Stanojevic
Message 7 of 27
Carbidecnc
Hi Ivan
Here are two photos, when my spindle was going CW and I had the tool as it was the orientation was perfect but spindle need to go CCW.As soon as I checked the box in tool setup the tool orientation changed managed to get it orientated right but the tip offset is totally wrong
Message 8 of 27
ivan.stanojevic
Okay, so you want your tool to be oriented like in the CW but the post needs to output M4 right?
Ivan Stanojevic
Message 9 of 27
Carbidecnc
Yes that correct Ivan
Message 10 of 27
ivan.stanojevic
Ok, in that case the best way is to change the variable inside your post processor. Can you share the post processor here?
Ivan Stanojevic
Message 11 of 27
Carbidecnc
Hi
Ivan
here is the post
Message 12 of 27
ivan.stanojevic
I've changed the variable to output M4.
Please test the attached post.
Ivan Stanojevic
Message 13 of 27
Carbidecnc
Thanx Ivan
all good
Message 14 of 27
Carbidecnc
Hi Ivan
Wonder if you could help me with something else.My machine doesn't go to machine zero(MCS) after (g53) is called which is the top right hand corner of the bed after part cut off instead close to the spindle
Could there be something else in the post processor that is causing this.
Message 15 of 27
ivan.stanojevic
Could you show me the code that you get?
And please mark how do you want it to look like.
You might want to change those two parameters when postprocessing:
Those are related with the block of code G53 X0 Z0 which is the home position of the turret.
Ivan Stanojevic
Message 16 of 27
Carbidecnc
Hi Ivan here are two pix as well first position of turret thats where it thinks g53 is second pic is where I would like it to be and where MCS IS ZERO.
ATACHED G code
The screen shot of the g53 positions that you sent me in the post processor  should there be any value in those lines
Message 17 of 27
ivan.stanojevic
Ok I understand. What machine do you have? Does it have y axis?
Ivan Stanojevic
Message 18 of 27
Carbidecnc
Hi Ivan
I have a BL-X30 WITH SIEMENS 808d anvanced controller no Y axis only z and x
Message 19 of 27
ivan.stanojevic
When you put your turret in the desired position what coordinates are on the screen?
Ivan Stanojevic
Message 20 of 27
Carbidecnc
Z0 X0
