Chamfers on flat end mills
info99H4D
info99H4D
Hi All,
Increasingly I'm seeing my tooling suppliers recommend ends mills with a small chamfer on the corners to improve tool life.  I have an application where I am needing to put a chamfer on a part with one of these end mills.  Unfortunately due to clearance issues it's not going to work with a typical chamfer mill so I am using a 10mm end mill with a .5 mm 45 degree chamfer on the corner however fusion won't allow me to add this feature to a regular flat mill.  Now I can change the tool type to a chamfer mill however that tool isn't supported for all of the operations so it's not a viable solution.
Would it be possible to add an option for corner chamfer when creating a flat end mill?
seth.madore
This is something that's been requested more than a few times over the years. Looking in our ticket system, I do find a recent ticket that's been opened (CAM-48372), so I've added this thread to the request.
Seth Madore
info99H4D
Much appreciated!
randypetrongelli
Form mill?
seth.madore
@randypetrongelli wrote:
Form mill?
That's actually not a bad idea. I thought there was a time when Form Mill tools weren't valid selections for Adaptive and Pocket toolpaths, but it appears that it just generates a warning about "invalid tool", but will generate a toolpath:
Seth Madore
randypetrongelli
Interesting, was just an idea, thanks for running with and proving it out.
seth.madore
It's worth noting a couple things;
1) Assuming my memory hasn't taken a turn for the worse, selecting a Form Mill is a relatively recent change. I cannot say for certain (at this point) whether it's intentional or not. It may or may not remain in the software
2) Fusion is only calculating as a straight endmill. It does not compute for any chamfer size; it will be leaving excess material in fillets.
Seth Madore
