Cancel Probed Rotation
a.hackney
a.hackney
I've created a program that uses a probed rotation (Haas NGC), but I want to limit the use of this rotation to the next 3 or 4 toolpaths only. Can the probed rotation then be cancelled by way of a ManualNC Action? For now I've hardcoded a #194=0 command into the NC program but I was just wondering on other ways of commanding the post to no longer output the rotation.
programming2C78B
is it not as simple as sending a G69 command? Then g68 to re-enable when needed.
Please click "Accept Solution" if what I wrote solved your issue!
a.hackney
The post outputs the G68 command on every toolpath after a probed rotation is carried out. I guess I'm looking for a way to switch the "flag" within the post processor?
The code does contain the necessary G69 command before a toolchange etc. but then a G68 is automatically commanded on the next toolpath.
programming2C78B
Depending on your order of operations, you can throw the unprobed toolpaths into a new "setup", but post them out together into one file. Could even be probed, not, probed again for example.
Does a manual nc put a g69 after the inserted g68? Why are some toolpaths not supposed to be rotated?
a.hackney
I've tried the multiple setup suggestion but I get exactly the same behaviour.
I have some features that need to be rotationally correct to another pre-machined feature, hence the reason for only certain toolpaths requiring the G68.
Thanks for your help so far
