- Mute
- Permalink
- Report
Hi everyone,
I'm running into an issue creating setups.
I have a design with two bodies in a single component:
One is the part I want to machine; the other is a solid body I’m using as stock
When I go to create a new Setup, I expect to see the "Model" selector (to pick the part I'm machining), but instead, I only see "Envelope" and "Fixture" options. There's no "Model" selection field at all, and I get a warning when I try to proceed saying no body was selected, and all visible bodies will be used.
This causes the stock body to be included as part of the machining model, which obviously creates problems in toolpath generation.
Has anyone else experienced this? Is there a setting or preference I might be missing that causes the Setup dialog to omit the Model selector entirely?
Any suggestions would be greatly appreciated!
