Can't generate tool path on circular segment
enkoping
enkoping
I try to generate CAM toolpath in Fusion 360 on a circular segment. I use 2D Contour whit a 5mm endmill.
This generate a warning. "Warning: Closed contour has 0 area."
I have tried different dimensions on both figure and the endmill. It works fine with half a circle, when it's more than a half a circle and every other shape I can think of.
seth.madore
I recall seeing this before. I think the solution was to break the arc into two moves. This can be accomplished with a "split face" line or a sketch that is also broken in two.
Seth Madore
enkoping
Thank you for your reply!
That was an easy fix to get me going again.
