- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm trying to use 2D Contour with a V-bit (chamfer) to engrave a pattern into an acrylic pickguard. At first I tried using the Trace toolpath, but Trace seems to turn all the curves into line segments, which caused my CNC machine to 'stutter' around the curves and produce slightly jagged cuts. So I thought I would switch to 2D Contour instead (which leaves the curves as arcs instead of line segments). To produce nice clean edges, I wanted to do a couple of shallow cuts in the acrylic. But in the Passes tab of 2D Contour, there was no Multiple Depths selection. I finally figured out that when you select a chamfer-type tool (which is how I set up my V-bit tool), the Multiple Depths option is missing. Does anyone know how to either: 1) get the Multiple Depths option back, or 2) suggest how to set up my V-bit as the type of tool that will allow the Multiple Depths option to appear in the palette? Or is there another way to solve this that I'm overlooking? I suppose I could just duplicate the 2D Contour setup a few times and make the depth of cut a little deeper for each one, but that doesn't seem very 'elegant'.
Thanks, Dan
