Can not get 3D contour down last section
I am trying to do a 3d contour down the inside of a funnel, I can not get it past the bottom of the funnel.  I have entry points from the top all the way to the very bottom of the funnel
My first op is running a 3/8 drill all the way through
1/2" rougher for the interior body of the funnel
1/4 ball mill for the contouring,
contour down the initial vertical section
then down the 45 degree slope
I need it to contour from the slope to the bore of the funnel so there is a very smooth transition
I cant figure out what I am missing to get it to go down the bore of the funnel.
Any ideas?
Thanks!  Ill try to post up screen shot in a bit
Steinwerks
Just a hunch: set the Bottom Height minus the radius of the tool from the bottom of the geometry. So in this case since you are using a 1/4" ball mill, select the bottom edge of your funnel face as the Bottom and input -.125 for the offset field.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
I changed the machining boundary to silhouette and tool containment to inside and it made the path correct all the way down the interior of the funnel spout.
I think I had changed it away from that earlier due to it attempting to machine the outside of the funnel.
Thanks!!!!
