Can not generate tool paths for one letter
Message 1 of 12
The software will not generate the correct tool path for the letter "A". It will only try to cut out the triangle of the letter, but not the profile. I have spent two days on this and many styles and variation of the letter "A". Any help would be much appreciated. Thank you.
Replies (11)
Message 2 of 12
daniel_lyall
Can you post the file Go to File -> Export and save as a .F3D Archive File and attach it to your next post
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 3 of 12
There you go
Message 4 of 12
daniel_lyall
It has me completely stumped.
 @jeff.pek Can you please have a look at this
Daniel Lyall
The Big Boss
Mach3 User
Message 5 of 12
Got it to work. For some reason Fusion would not recognize the outside profile of the letter "A". So I traced it and now it works off my trace lines. Not a fix for the problem, but a work around.  Thank you for your help.
Message 6 of 12
daniel_lyall
There's something wrong there, that's why I past up the chain.
Daniel Lyall
The Big Boss
Mach3 User
Message 7 of 12
porsbym
We end up with a small gap in the outer contour of the A, which then gets dropped. You can more easily see this if you add a trace operation with the same geometry:
I have added ticket CAM-7606 to track this problem, and hopefully we can fix it for one of the next updates.
/Mark
Message 8 of 12
daniel_lyall
That is a strange one you can extrude that letter
Daniel Lyall
The Big Boss
Mach3 User
Message 9 of 12
porsbym
I suppose the modeling side of things is more tolerant to this kind of geometric issue.
Nevertheless, we will see if we can improve this in CAM.
/Mark
Message 10 of 12
Yes. I could extrude it. I re-did that letter at least 20 times or so, from several different software and several different versions. I then line traced it in Fusion and that worked. I spent two days on that stupid letter. lol
Message 11 of 12
Message 12 of 12
daniel_lyall
It happens sometimes At least you got what you needed in the end
Daniel Lyall
The Big Boss
Mach3 User
