Can Fusion Program this? I'm thinking no. Help!!
motoxprepper
Message 1 of 12
motoxprepper
I have a little winch drum that I am trying to make as a test piece to prove that it can be done. I know it is physically possible on a 2 axis cnc lathe, but I cannot figure out how to get Fusion to program the groove features, as its somewhat complex. This style of groove is called a "Lebus" groove. It is basically a straight groove for 270deg of the circumference, then it shifts over to the next groove in the other 90deg of circumference at a set pitch. So basically a threading program that only threads one quarter of a revolution of the spindle, and is stationary the other three quarters revolution. Any help would be appreciated, or even if you can help with coding this by hand, I am desperately trying to figure this out. I have hand coded some g32 lines, and that seems to be the way to do this, but can not get it to do what I want. (Fanuc)
Link to part model:
https://a360.co/3NllA3g
Video of it being successfully done:
https://www.youtube.com/watch?v=oODOEYbdSSw&list=FLgf0zYgeQnvDRiMpykczWmQ&index=4
Replies (11)
Message 2 of 12
a.laasW8M6T
Hi
You are correct, fusion cannot do this.
I'd be surprised if any cam software could.
That video does show the code and macro on how they do it in G code. why not just use that?
Andrew Laas
Senior Machinist, Scott Automation
Message 3 of 12
motoxprepper
That is not a Fanuc control, so I was worried about compatibility issues. I
guess it would not hurt to try.
Message 4 of 12
a.laasW8M6T
If you understand the logic there should be no problem adapting the syntax to your particular control
Andrew Laas
Message 5 of 12
satinalmaM9UHS
This is not a motion that can be programmed with these G codes.  If you manage to machine this by turning, let me know as well.
Fusion can do this, if you have a C axis lathe.
Message 6 of 12
satinalmaM9UHS
My advice would be to use 30 + 150 + 30 + 150 degrees instead of 90 + 270 degrees.
Message 7 of 12
programming2C78B
How do you model something like this?
Can you cheat it and do a 4th axis mill code but with a non-rotating Turning tool? Would probably have to be a round button insert if so.
Please click "Accept Solution" if what I wrote solved your issue!
Message 8 of 12
satinalmaM9UHS
I prefer to do the modeling in AutoCAD and add some auxiliary lines in the model to help me create the toolpath. However, instead of machining it by turning, I use live tooling and machine it with a ball-nose carbide end mill having the same diameter as the groove.
As for the design, it definitely needs to be revised. A steel wire rope cannot make such a sharp turn as you have drawn.
Message 9 of 12
motoxprepper
This was just going to be a test part anyways. But really, this would not even be close to the size we are planning to make for drums. We are planning for anywhere from 12" O.D. to 72" O.D, with lots of different wire rope sizes. possibly bigger in the future. I am working on a macro program for the double transition Lebus now. Will let you know once I get it ironed out.
Message 10 of 12
satinalmaM9UHS
I would appreciate it if you could share it with me as well. I had asked this same question on this forum before you. If you share your final design, I may be able to give some advice.
Most likely, the groove on the drum will continue inside a cover that you will place at the end of the drum. And in order to make this transition seamless, using live tooling with a programmed operation will be more practical for keeping the dimensions under control. I’m curious about the result.
Message 11 of 12
motoxprepper
We do not have any machines with live tooling here. I wish we did! It would
be much easier.
Message 12 of 12
john.ning
If you could handwrite codes from the thread variables you are doing, then you can modify the post to do the same thing.
