- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
After making the first run of some wheel spacers I designed, I decided to replace some edge chamfers with a radius using a 1/4 round end mill. This required adding the radius feature to the CAD model after having already generated all the tool paths for the other operations. I have three different variations of the spacer so making the changes to each required a fair amount of work. Now when I post process the programs, I get the following warning:
Warning: (/Users/Tim/Autodesk/Fusion 360 CAM/Posts/PPWithProbing.cps:1898) redeclaration of function onParameter
I've searched the forum, YouTube and Google and can't find an explanation for this warning. I'm using a post processor from David Loomes for my Tormach 1100MX. It appears to post process fine and everything acts the same as before. I'm not able at this time to actually run the program so I don't know if this is going to be a problem when it comes time to actually make the parts. I've attempted to attach the file to this post. Any suggestions would be appreciated.
Thanks, Tim
