Cam simulation poor graphics
stuart
Message 1 of 30
stuart
Hi all
Im getting really poor graphics on my Cam Simulation.  Anyone have ideas what to check to improve?  Also the default is Mirror.  Maybe its my pc but this looks terrible compared to Ceramic which I find a bit light.  Whats everyone using?
Replies (29)
Message 2 of 30
LibertyMachine
You likely have it in "Fast Mode":
Change it to "Standard" and you should see some improvement.
Personally, I leave it at Mirror. Not because I like that look, but it's the only setting that allows the colors of the part to change at each tool. I find that to be a very valuable aid in programming, as it helps to provide a visual aid as to where the tool is touching and where it may not be performing as expected. With the "Wall Paint" setting, everything is a lovely shade of ivory with no distinction in between tools. If they could make it work in those modes, I'd jump in a heartbeat
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
Message 3 of 30
Steinwerks
@LibertyMachine
His screenshot shows it's in Standard already.
Personally I like Wall Paint but that's me.
@stuart How small is the feature? The smaller things gets, generally the more "pixelated" the simulation looks, I believe due to the way that it utilizes the STL calculated in the background.
Can you share the part at all?
@fonsecr is there any insight as to what can improve these in Fusion? I've had similar concerns in the past with surfaced toolpath simulations.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Message 4 of 30
LibertyMachine
@Steinwerks DOH! I saw the picture and looked at it, but didn't even see the Sim dialog >.>
Seth Madore
Message 5 of 30
brad_francola
We struggle with graphics quality on turning simulation (see below).  Are there and "secret" settings that increase graphics resolution?
Message 6 of 30
LibertyMachine
Other than what is already there, no.
We have Fast Mode which gives a really shoddy display, and then we have Standard mode.
Can you share your file, I don't recall ever seeing something that low res
File > Export > Save to local folder. Return to thread and attach the .f3d file in your reply
And just a friendly note; posting the same question in multiple threads is not an encouraged behavior. Leads to clutter and duplicate conversations taking place as other people visit the forums.
Seth Madore
Message 7 of 30
brad_francola
Thank you for the friendly reminder...I feel great shame for multiple thread postings...   Smiley Sad
File is attached.  Thank you for your help.
Message 8 of 30
LibertyMachine
Nope, certainly getting the same thing as you. Ugh, ugly.....
Seth Madore
Message 9 of 30
brad_francola
Thanks for looking a this.  Do you think this will draw the attention of the developers?
Message 10 of 30
LibertyMachine
It's possible. I'll poke a few people I know and see if I can get them to chime in with some thoughts and comments.
I guess the problem has always been there, but most generic lathe parts tend to be a good deal bigger. With the consideration of Swiss Turning in the (potential) developmental pipeline, something is going to need to be done to improve things in this area
Seth Madore
Message 11 of 30
Steinwerks
This is just from my email so I haven't looked at the post in question, but
try tightening all the tolerances in the Setup (like Spun Profile etc.) and
see if that helps.
Neal Stein
Find me on:
Message 12 of 30
brad_francola
Thanks. We are trying your suggestion. We haven't found any settings that make the graphics look better but we will keep trying.
Message 13 of 30
I'm having the same issue with poor simulation graphics
Message 14 of 30
akash.kamoolkar
Hey guys,
I've forwarded your request to our new development team working on Fusion simulation. I'll keep you posted on any updates.
Akash Kamoolkar
Akash Kamoolkar
Software Development Manager
Message 15 of 30
brad_francola
That is awesome news!  We have several guys using Fusion360 at this point.  They really like the software and it is helping them get things done. Thanks!
Message 16 of 30
brad_francola
Hello Akash,
We continue to see strange things during Simulate.  I've attached the file if you'd like to look at it.  Generally speaking, it seems like there needs to be a way to "dial up" the resolution - we work mostly with small Swiss parts.  Quite often, our inserts are larger than our parts.
-Brad
Message 17 of 30
akash.kamoolkar
Thanks @brad_francola This is very helpful. I have attached this file to our task as a good test case.
Akash Kamoolkar
Akash Kamoolkar
Message 18 of 30
brad_francola
Awesome!  Also, you may want to look at that grooving toolpath.  We had to "lie" about the width of the insert in order to get a simple plunge type groove. All that aside, the software keeps getting better and better.  Thank you for your hard work.
Message 19 of 30
akash.kamoolkar
We're looking to fix the issue with the grooving toolpath but for now as an alternative you can use the single groove operation if all you want to do is just plunge in and out.
Akash Kamoolkar
Akash Kamoolkar
Message 20 of 30
brad_francola
Cool.  I feel dumb for not trying that first.  Single groove is super easy.  Thanks.
