- Mute
- Permalink
- Report
While running a CAM simulation on a particular part and toolpath, Fusion 360 inevitably crashes. So far, this occurs at least once out of every two simulations. Fusion will hang, parts of the menus will go black, the spinning "thinking" mouse pointer icon will appear, and it will remain like that indefinitely (>30 minutes) until I manually kill the program. There is no error dialog popup. The location in the toolpath at which is freezes is not consistent.
System Specs:
- Windows 10
- CPU: Intel Core i7-10510U
- CPU Memory: 16 GB
- GPU: Nvidia Geforce MX230 w/ 461.09 driver (and Intel Integrated GPU, which is not used for Fusion)
- GPU Memory: 8 GB
Fusion Graphics Settings:
- Driver: DirectX11
- Transparency Effect: Better Performance
- Limit effects during navigation to maintain framerate: On
- Limit effects when graphics memory is low: On
Fusion Preview Features:
- HighDPIScaling: Off
- Blend Strategy: On
- Continue Rest Machining for Milling: On
- In-Process Stock - Mesh Check Safety: Off
- In-Process Stock as Remaining Stock: Off
Fusion Graphics Diagnostic Menu:
- Limit effects to optimize for performance: On
Simulation Settings:
- Mode: Standard
- Colorization: Comparison
- Tolerance: 0.002
Toolpath Operations:
3D Pocket:
- Rest Machining: From previous operations
- Use Morphed Spiral Machining: On
- Radial Stock to Leave: 0.02
2D Contour:
- Chamfer: On
- Nothing else special
I've played with all of the settings above, tried OpenGLCore and DirectX9 & 11 for the driver, turned on and off every toggle. At this point I believe I have permutated all of the possible combinations.
I cannot upload the full model at this time, but I can provide screenshots. Any help would be great, as this is costing my company money.
Additional Information:
- The model is natively created in Fusion360
