Message 1 of 11
12:16 PM
- Mute
- Permalink
- Report
Fairly new to Fusion360,using diy CNC called LowerRiderCNC which is working. I have been able to cut panel and cut pockets.
I am trying to engrave text and the text is being cut backwards. Instead of "word" it cuts "drow".
Fusion 360 simulate looks correct when run.
My design process is that I create a rectangle and extrude it to the wood height. On the top of the wood I create new design and place the text (I do have to flip it 180).
Appreciate if you could provide directions of what sequence I need to go through to get this oriented correctly,this has been a very frustrating experience.
Thanks in advance for your time to review and reply.
