CAM Setup Error – Kinematics Conflict (Line 760)
nahum_garcia
Observer Observer
nahum_garcia
Observer
Observer
Hi everyone,
I'm getting this error in Fusion 360 while working in the CAM setup:
"Error: You can only select either a machine in the CAM setup or use the properties to define your kinematics. Error at line: 760"
I'm not sure what is causing it. I have a machine selected in the setup, but I don’t know if there's a conflict with the kinematics settings or the post-processor. Any ideas on how to fix this?
Thanks!
CGBenner
@nahum_garcia
Welcome to the community.  I moved your post to this forum for better visibility with the Manufacturing community.  Good luck!
Chris Benner
viacheslav.shapilov
Hello, @nahum_garcia .
What post are you using? It looks like you probably trying to define machine twice - once on Fusion side and in post properties. And post says that you should not do this. If you define machine using post properties, don't attach machine to the setup, or use it in NC program.
Viacheslav Shapilov
Developer Technical Services
Autodesk Developer Network
CGBenner
@nahum_garcia
Hello, do you still need help with this question?
Chris Benner
