CAM: Remove operation sequence randomization in "Pattern"
Willa1980
Willa1980
The sequence of milling operations is randomized when moving them to a pattern folder. Please see the video. I think this is a bug.
innovatenate
Autodesk Support
Autodesk Support
What operations order is selected for your pattern?
Nathan Chandler
Principal Specialist
Willa1980
I just tested that, it doesn't matter. It is always randomized. These settings should IMHO not affect the order of the operations anyway. They should just affect the order of the pattern strategy.
innovatenate
Autodesk Support
Autodesk Support
Upon closer look, I see what you mean about this behavior. I'll look into this further and circle back in this post. Thanks for reporting this!
Nathan Chandler
dave.anderson
I've logged this with the developers in ticket CAM-4438.
Dave Anderson
Sr. Support Engineer– CAM
