CAM no longer functions after the update.
johann.pascher
Message 1 of 11
johann.pascher
CAM no longer functions after the update. Toolpaths are not being processed, yet no error message is displayed. In the image, the top part shows how they looked before the update, and the bottom part shows how they appear after the update. I would like to revert to the version before the update. Reinstalling it has not made any difference.
Replies (10)
Message 2 of 11
g-andresen
I think your question actually belongs in the Manufacture Forum
Maybe  @seth.madore can also answer here?
günther
Message 3 of 11
johann.pascher
Is not about the menu feature at all, it just stopped working correctly after the update.
Message 4 of 11
seth.madore
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
And no, reverting to an older version of Fusion is not possible.
Seth Madore
Message 5 of 11
johann.pascher
file attached
Message 6 of 11
johann.pascher
File attached, hope it worked this time.
Message 7 of 11
seth.madore
The issue is that in your Setup, you have your Model selection and your Stock selection set to the same bodies. The Stock should be changed to either:
Relative Size Stock with no extra material
or
A different solid model that doesn't have the cutouts.
Result of choosing the former option:
Seth Madore
Message 8 of 11
johann.pascher
Okay, thank you very much. It did work before the update. For me, it's just a workaround that gets the job done. But, it's still a bug in my view because no explanation is provided. Thank you very much for looking into it.
Message 9 of 11
seth.madore
No, it's not a workaround, the way you were setting up your job was incorrect. According to the toolpath kernel, there is no material there. That it worked before was the actual bug.
Seth Madore
Message 10 of 11
johann.pascher
OK thanks. From what I understand now, my previous result was based on a bug that has been fixed.
Message 11 of 11
seth.madore
correct
Seth Madore
