- Mute
- Permalink
- Report
I've been using Fusion360 learing modeling and CAM and I'm trying to fire up my CNC router with a little project using my companies logo.
I've modeled this a bunch of times and each time has different problems when trying to do the CAM.
This latest version just straight up errors out trying to do a toolpath of any kind (error message box "failed to create toolpath") I'm hoping someone can look at the upload and school me on how I'm screwing this up.
I even had a guy at work clean up a STEP export in a different product and when I import that (its actually a simpler version without the letters) and try to CAM its a bunch of different errors.
Just as an example of the problems I've run into. I could do adaptive clear on the top left but doing the exact same setup on the top right it would fail to generate. Then I was able to do both the smaller areas but not the larger bottom area (again with the letters gone).
Please teach me. I'm about ready to pull my hair out.
I think part of the issue is I imported a SVG. I took out the outer arcs from the SVG and remodeled them to make the geometry cleaner as the SVG version wasn't perfect matching arcs.
