- Mute
- Permalink
- Report
When generating a 2D contour path initially the path was generated successfully then after making a small change to an offset I get this error:
All of the other tool paths generated successfully. I deleted the problem 2D contour path and then inserted a new 2D contour with the settings revised to match the one I just deleted. It would generate and looked ok but I had to make a small correction and then it failed to generate with the error message above.
What just happened? I searched the forum and cannot find anything on this error.
File is attached
Dick
