CAM axis orientation for a cylinder
I am wanting to cut slots along the horizontal axis of a cylindar.  I can not get the z axis to go perpendicular to my peice.  When I select the z axis in the orientation that I will be machining the stock direction changes.  Any suggestions?
Steinwerks
In the stock tab you should be able to select the cylindrical surface to orient the stock to the model.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
HughesTooling
The trouble with selecting the cylindrical surface is the Z then points along the cylinder not perpendicular to the flat faces or is there something I'm missing.
I think the only option is make a component draw a cylinder to use as the stock and select From solid.
Mark
Mark Hughes
Owner, Hughes Tooling
Steinwerks
I made a screencast. This should work just fine or there might be something else going on. I did this with both Fixed and Relative sized cylinder stocks.
Neal Stein
Find me on:
HughesTooling
I must have been asleep still, missed the Axis selection on the stock tab completely.
Thanks Mark
Mark Hughes
thanks for taking the time to answer my question.  Seems so simple now
