Bugs. Sync view with active setup and sync viewcube.
HughesTooling
Consultant Consultant
Message 1 of 9
HughesTooling
I find the sync view and viewcube with active setup quite useful working on assemblies but there is a bug when you select a folder or pattern, the view and viewcube go back to the document settings.
Here when I activate a setup I get the correct view i want.
But when I select a folder within the setup it switches to this orientation.
Mark Hughes
Owner, Hughes Tooling
Replies (8)
Message 2 of 9
programming2C78B
Can confirm its also happening here, only after updating
Please click "Accept Solution" if what I wrote solved your issue!
Message 3 of 9
HughesTooling
@seth.madore Can you log this please?
Mark Hughes
Message 4 of 9
rasmus.pedersen
Hi @HughesTooling @programming2C78B this is a known shortcoming of the original sync view implementation. We do have a ticket for this. I will find it a post here shortly.
If you feel this is something that would be useful we can look into making it behave (i.e when activating a folder) as if the setup was being activated.
Rasmus Pedersen
Senior Software Engineer
Message 5 of 9
rasmus.pedersen
Here is the ticket CAM-60810.
Rasmus Pedersen
Message 6 of 9
HughesTooling
Yes this is definitely useful. It's quite irritating trying to work with patterns and folders that make the part rotate to a different orientation all the time. The sync view cube and sync view are really helpful working in assemblies and on parts machined on several sides but having the view change just because you activate a folder is distracting.
EDIT. Also if this is looked at and improved, when a folder or pattern is activated it should not change the view at all. I would not want it to act like I've selected a different setup and reset the view and zoom out.
Mark Hughes
Message 7 of 9
FrodoLoggins
Yup. Definitely get that too. This ****ing POS
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
Message 8 of 9
programming2C78B
"known shortcoming of the original sync view implementation"
But it just started with the latest update???
The original sync worked!
Message 9 of 9
rasmus.pedersen
@programming2C78B I think Fusion might have started (since last update) to allow activate view sync on folders (as part of some recent work). Previous that would have been ignored. I will look into this more once I get some time.
I imagine the fix will be to keep allowing folders/patterns to be activated but then fetch the setups transformation.
Rasmus Pedersen
