Bug when saving pdf of nest reports
steve3957T
steve3957T
Pretty sure this is a bug as it seems to be 100% repeatable for me:
When saving a nest report to .pdf, there is a second "page setup" window that pops up that you must "ok" in order to save the .pdf.  If I accidentally close the report window first, then hit "ok" on the page setup window, I get a crash to desktop.
Also, when I get crashes while in the manufacturing space, the recovery file will delete all nesting information and all setups, which is not ideal.
jeff.pek
Are you able to capture a screencast of this happening?
As for the recovery file, was Fusion alive long enough for the auto-recovery to have included that information (default = 5 minutes)?
  Jeff
steve3957T
Hi Jeff,
See attached for the recording of the crash. Yes, the file I was working with today was open several hours before the crash.  I don't think I have ever successfully recovered manufacturing information when the crash happens in the manufacturing workspace.  Manufacturing info will be recovered if the crash takes place in the design space, however.   I can share some files if you think they will help.
