Bug when saving pdf of nest reports
steve3957T
steve3957T
Pretty sure this is a bug as it seems to be 100% repeatable for me:
When saving a nest report to .pdf, there is a second "page setup" window that pops up that you must "ok" in order to save the .pdf.  If I accidentally close the report window first, then hit "ok" on the page setup window, I get a crash to desktop.
Also, when I get crashes while in the manufacturing space, the recovery file will delete all nesting information and all setups, which is not ideal.
jeff.pek
Are you able to capture a screencast of this happening?
As for the recovery file, was Fusion alive long enough for the auto-recovery to have included that information (default = 5 minutes)?
  Jeff
steve3957T
Hi Jeff,
See attached for the recording of the crash. Yes, the file I was working with today was open several hours before the crash.  I don't think I have ever successfully recovered manufacturing information when the crash happens in the manufacturing workspace.  Manufacturing info will be recovered if the crash takes place in the design space, however.   I can share some files if you think they will help.
steve3957T
Hi Jeff,
Here is another video showing the opening of the recovery file.  You can see that on the initial opening, the setup information appears to be there for a few seconds, then all the setups break and are no longer there.
