**BUG REPORT - Manufacture workspace - Tools unexpectedly change when editing a copied operation - Not fixed -
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
**Editing this original post - the problem is still present, not fixed. Apologies thought it was fixed before**
When copying and pasting a setup from a similar part, the tool and parameters change unexpectedly.
I use a simple copy and paste method with most of my programming work to save time. I simply re-point the missing tool paths, top and bottom selections, etc. After this recent Fusion update, when editing the copied operations to correct the missing selections (contour, drill, pocket, etc.), the tool and parameters change unexpectedly causing a big headache now.
Step 1 - Paste copied Drill operation w/ 1/4'' cutter (showing the missing selections error):
Step 2 - (R click, Edit) to fix the operation by reselecting the missing hole faces and depths - the tool changes instantly to something else:
*UPDATE & correction* - This is still not fixed
