BUG: F360 never selects the specified post processor when exporting gcode
JetForMe
JetForMe
For the last couple releases, at least, when I go to export (post process) the generated gcode, I always have to select the post to use, even though the machine configuration has the correct post selected. This happens in both lathe and additive setups.
Here you can see the machine selected in the Setup, some of the machine's configuration, and what the default export settings look like:
It's very frustrating to have to always select the post processor, and if I ever forget, I could get dangerous gcode.
Also note that document machines include a lathe, even though I never created a setup that uses a lathe. Not sure what that's all about.
macOS 10.15.4, F360 2.0.7830
MacBook Pro, PCNC1100 Series 3, Slant-PRO 15L Lathe, Custom AvidCNC-based 4x9' CNC Router w/24k 4.5 kW HSD Spindle & Teknic SDSK Servos
engineguy
@JetForMe
Known bug, been waiting for this to be rectified for a while, the connection between the Machine Configuration and the Post Processor got broken somehow, the PP reverts to the last one used which as you rightly point out is a real pain, it has been reported, be careful !!!
Stay safe !!!
Regards
Rob
JetForMe
Is there a proper bug repo, or just this forum?
daniel_lyall
This forum unless you go through a resaler
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
