bore toolpath not working
j_cavender
Message 1 of 15
j_cavender
hello every since the last update i cant get the bore toolpath to work
Replies (14)
Message 2 of 15
LibertyMachine
Do you mean this Bore toolpath:
Or this one:
You should be using the first example. but I can't say that I've had any issues with it, even though I've used it several times recently
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
Message 3 of 15
j_cavender
the first example
Message 4 of 15
LibertyMachine
Can you share an example that is not working so we understand what you are dealing with?
File > Export > Save to local folder. Return to thread and attach the .f3d file in your reply
Seth Madore
Message 5 of 15
j_cavender
how do i send you an a360 link it has some linked componants in it
Message 6 of 15
LibertyMachine
You could right clink on the file in the Data Panel and select "Share Public Link" or just invite me to the project
Seth Madore
Message 7 of 15
j_cavender
https://a360.co/2zH1XfP
password is booger
Message 8 of 15
LibertyMachine
Hmm, not seeing the issue:
Seth Madore
Message 9 of 15
j_cavender
it wouldnt work for me i was trying to do the headstock from the other side
Message 10 of 15
LibertyMachine
That's because the fingerboard area is not along the same plane as the Headstock. You selected the Fingerboard area in your Setup. Try selecting the Headstock area and you will be fine
Seth Madore
Message 11 of 15
LibertyMachine
Seth Madore
Message 12 of 15
JDKnives.customworks
Community Visitor
Community Visitor
I am having the same issue with the bore tool path not working with an empty message log... i have used this tool path with a similar set-up successfully many times. There are some differences that should be noted, I have converted all the bodies into components. I then copied each component for a multiple of 2 of each set I did not paste as new though so they are connected, however as far as I knew the CAM should only be concerned with the model itself and not with the bodies' dependency on the parent component.bore toolpath no beunobore toolpath no beuno
Message 13 of 15
daniel_lyall
You would need to post a model so it can be worked out what is wrong To do this Go to File -> Export and save as a .F3D Archive File and attach it to your next post, if you can not post the file you can PM it to me or say in your next post you can not post the file and one of the Guys that do NDA work will help.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 14 of 15
Community Visitor
Community Visitor
thank you for your reply... I ended up figuring it out, kind of. Even though I aligned the pasted component to a body derived from a native plane, it was out of whack somewhere along the lines. Instead I re-pasted and used the move tool, point-to-point, instead of the align tool, it worked and my parts are on their way. Hope my hair pulling helps someone else...
Message 15 of 15
HughesTooling
You should use joints for this, of course you also would need all parts as components as well. Both of these are best practice, use components, avoid move\align and layout using joints. Reading your first post you should be designing using Rule#1, converting bodies into components is not a good idea.
Mark
Mark Hughes
Owner, Hughes Tooling
