Best toolpaths to use
davidsimpson227
Message 1 of 9
davidsimpson227
Hey y'all, I'm having difficulties figuring out the best toolpaths to complete this part. I've studied and tried different things but haven't used anything outside of the normal 3D adaptive, flow and parallel on the 3D side of things, so it is making it quite difficult. I know this would probably relatively simple, if I knew what other toolpaths would be most efficient. I have attached a step file of the part. Mat'l is 7075 ALUM if you need to know. If someone could please help me out, I would very much appreciate it.
Replies (8)
Message 2 of 9
programming2C78B
"3D adaptive, flow and parallel" will make all of that part. What are you missing out on? Where is your CAM setup? Machine? Available tooling?
Please click "Accept Solution" if what I wrote solved your issue!
Message 3 of 9
davidsimpson227
I attached the step with the path I have as of now. It's not that I'm missing out, I'm just not too confident in it, as I feel that there is probably a much better/more efficient way to do this. The machine is a haas vf2ss, 3 axis, and the tools are: 1/2 rougher, 1/2 finisher, 1/4 bn, and i have the drills according to each hole dia. Tools aren't an issue as i have access to many more. I'm just self taught and come here to learn much from experienced programmers.
Message 4 of 9
a.laasW8M6T
Hi
A step file is no good as it does not contain any toolpath data.
You need to export the file in the Fusion native format .f3d/.f3z
.f3z files will need to be zipped to upload to the forum due to a forum bug
Andrew Laas
Senior Machinist, Scott Automation
Message 5 of 9
davidsimpson227
Thank you, I was unaware of that! Are you able to see it now?
Message 6 of 9
programming2C78B
I'd do Parallels on the flats and Contour/Ramp/Geodesic on the angled walls.
.002" stepover is quite small IMO. .005" at least.
Your feed can be WAY higher (200%). Remember that you're re-cutting with every pass.
Message 7 of 9
davidsimpson227
Ok that makes sense now that I've played with it a little, Thank you! On the angled and vertical walls, would you run the cutter vertically or horizontally? Which would give the best finish?
Message 8 of 9
davidsimpson227
Nevermind, just realized it doesn't give the option to change pass direction. I appreciate your help very much!
Message 9 of 9
programming2C78B
in general you always surface in the "long" direction of your feature to spend less time accel/decelerating
