Ball End Mill Slot Along Z Axis Angle... How Do I Do It?
morgantooldie
morgantooldie
Im trying to mill this slot with a 1/8" ball end mill. I want to follow the centerline of the path and just step down in Z Axis increments. How do I do that? F3D file uploaded as well. Thanks in advancetee bracket.jpg
Steinwerks
The simplest way to do this with your part is probably to create a sketch with a line down the center of the groove, then use the Project toolpath under the 3D section. Use Axial Offset Passes on the Passes tab to mill it in steps.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Laurens-3DTechDraw
Exactly, and pretty sure you can use the tangential extension so it starts outside of the part.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
morgantooldie
Worked great. Thanks!
