Automatic Corner Slowdowns
LibertyMachine
Mentor Mentor
Message 1 of 8
LibertyMachine
AKA Feed Optimization
Is this a function of a post edit or is it Fusion driven? Trying to implement it in a part and it doesn't seem to be doing anything when I post it out, holding one feed across the board.
If I can't get it to work, it's not a HUGE deal, as the Fanuc control does allow for that calculation, it just is going to screw up my other programs that already have the slowdowns programmed in (customer supplied programs)
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
Replies (7)
Message 2 of 8
Steinwerks
Not at my computer right now, but if you haven't done so, click the "inside corners only" box.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Message 3 of 8
LibertyMachine
Yeah, it was. Looking through every tooltip in that dialog, it seems that every option is set as it should be. Scratching my head wondering why it ain't slowing down
Seth Madore
Message 4 of 8
HughesTooling
It works is you set the rad to 0.301 but it seems to ignore Only Inner corners.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 5 of 8
Steinwerks
I totally spaced it. HSMWorks had this same issue. UNcheck Inside Corners Only. It will ignore outside corners entirely for feed optimization.
Neal Stein
Find me on:
Message 6 of 8
LibertyMachine
I see what I did wrong. I was understanding the "minimum inside radius" to mean that anything over that would force a slowdown. It's anything UNDER that radius.
@HughesTooling yeah "Only Inner Corners" does nothing it seems. All outside rads have the slow down as well
Seth Madore
Message 7 of 8
I believe the minimum inside radius is the smallest radius the centerline path the tool follows can have before a slowdown. Usually a .01-.03 value is a catch all for any radius close to the cutter size.
Message 8 of 8
thomas_crescenzo
Observer
Observer
What were your final settings that got feed optimization to work? I've tried a number of different settings with large and small corner parameters, checked and un-checked "only inner corners" and still can't seem to get feed optimization to generate any slower feed areas.
Additionally when I have feed optimization enabled it seems to cancel my finishing feedrate on finishing passes for the operation and do all passes at the roughing rate. When I turn it off I get a proper finishing feedrate again. Any ideas?
Thomas
