are setup sheet configurations just gone ? or am I missing something?
jeff2HS8X
Message 1 of 15
jeff2HS8X
cant find my setup sheet configurations anymore after the update. I still see mine in the "assets" folder, but can't access it
Replies (14)
Message 2 of 15
jeff.pek
Hi -
Can you answer some questions about this?
1. Do you know when these seemed to go missing? (You say it was following an update)
2. Can you share your diagnostic logs with me? Feel free to send via DM.
3. Do you use other machines with Fusion? Are other people sharing your Team, or are you the only one?
  Jeff
Message 3 of 15
jeff2HS8X
Hi Jeff,
      Yes, it seemed to go missing right after I did an update to the latest version of Fusion, which was earlier this week on Tuesday I believe.  And I do have two other users that I share a team with, both of which have their own permanent machines that they work from. I have the diagnostic file attached.
Thanks for reaching out ,
Jeff
Message 4 of 15
jeff.pek
Thanks, Jeff.
Can you double check that Cloud Libraries are enabled in your Manufacturing preferences? I don't see any evidence in your logs of anything actually getting deleted.
Jeff
Message 5 of 15
jeff2HS8X
I just double checked and yes the cloud libraries are enabled.
Message 6 of 15
jeff.pek
OK. Can you try this:
1. Shut down Fusion completely.
2. In Explorer, go to directory %localappdata%\autodesk\autodesk fusion 360\<userid>\w.login.
3. Rename the directory M (e.g., to M-save)
4. Restart Fusion.
Let's see if that causes things to resynch.
Jeff
Message 7 of 15
jeff2HS8X
so I dont see my actual user ID. however I see a folder "unknown user" and inside the "unknown user" folder I find the W.login folder then a folder "F" within that, not "M"   .  should I change the F to F-save ?
Message 8 of 15
jeff2HS8X
nevermind , found the M folder. trying it now. I will let you know how it works
Message 9 of 15
jeff2HS8X
Jeff,
    unfortunately that did not work...
Message 10 of 15
jeff.pek
OK. Do you know if these files got deleted at some point, and then were restored from the trash bin?
  Jeff
Message 11 of 15
jeff2HS8X
Not that I am aware of, I just checked my trash bin and there is just a bunch of deleted screenshots in there.
Message 12 of 15
jeff2HS8X
Also, If I got to "preferences" and "preview features" I actually dont even see "set up sheet configurations" as an option...
Message 13 of 15
rw_skinner
I checked on mine and if I right click on a NCProgram then setup sheet is in the menu.
Message 14 of 15
jeff2HS8X
yes I still have set up sheets also, but I dont have any access to my custom set up sheet that I have been using for a while now.  basically when I go to create a set up sheet (again i CAN do that) it only gives me the option to create one of the default set up sheets from the drop down list...(detailed, tools only, compact, etc...). not the one that I have custom configured...  screenshot attached
Message 15 of 15
jeff.pek
Are you a member of the Fusion Insider program? A few updates ago, we moved all preview features to be only available to insider users. The Setup Sheet Configurations preview feature is one of those that moved.
So, you will probably need to join the insider program to get access back to that.
Jeff
