April 2025 Post Processor and Machine Simulation What's New
andrea.amilo
Community Manager Community Manager
Message 1 of 1
andrea.amilo
Post Processor and Machine Simulation What’s New
Looking for the latest post processors and machines updates? Look no further!
We are continually working hard to bring you updates and improvements to the many open-source Post Processors and Machines we offer for free, but those updates often get lost in the shuffle of other enhancements or big feature releases. This post aims to update you on newly added or improved post processors and machines, so you can stay up to date on what you use today or look for news so you can get the most out of Fusion.
This post will get refreshed with notable updates as they’re released, and you can click each hyperlink to go to the mentioned post. As always, you can find the latest in our post processor offering on the Online Post Library where you can search by vendor, type, or name, and see any recent changes to each post processor.
MAIN CONTENTS
  1. Improved Post Processors
  2. New Machines
  3. Improved Machines
  4. New Print Settings
  5. Improved Print Setting
  6. Documentation
  7. Post Processor Engine
  8. Post Processor Ideas
We are always working to keep post processors up to date with new technologies. This is a summary of the main improvements made to post processors already in the library.
Milling Post Processors
Osai
Updated the Osai post to use shared content across post processors.
RS-274D Multi-Axis
Updated the RS274 Multi-axis post processor to the latest capabilities of the post kernel.
Siemens Sinumerik ONE, Siemens 828D, Siemens 840D, Siemens 840D Inspection
Added Live Connection support to the Siemens Inspection postprocessor.
Tormach PathPilot
Fixed potential issue when the 'SmartCool equipped' property is enabled in the Tormach post processor.
Turning Post Processors
Haas Turning
Changed Chip Breaking cycle to use IJK attributes in Haas turning post processor.
Heidenhain Turning
Added Support for G33 Turn Threading and Fixed Feed formats in the Heidenhain turning post processor.
ProtoTRAK Turning
Added the G76 threading cycle in Prototrak Turning.
Mill-Turn Post Processors
Fixed RPM checks with max spindle speed property for non-live tools in several mill-turn post processors.
Haas CL-1, Haas DS-30Y, Haas DS-30SSY, Haas ST-10, Haas ST-15, Haas ST-20, Haas ST-25, Haas ST-28, Haas ST-30, Haas ST-35, Haas ST-40, Haas ST-45, Haas ST-55, Haas ST-10L, Haas ST-15L, Haas ST-20L, Haas ST-25L, Haas ST-28L, Haas ST-30L, Haas ST-35L, Haas ST-40L, Haas ST-45L, Haas ST-10Y, Haas ST-15Y, Haas ST-20Y, Haas ST-25Y, Haas ST-28Y, Haas ST-30Y, Haas ST-35Y, Haas ST-10LY, Haas ST-15LY, Haas ST-20LY, Haas ST-25LY, Haas ST-28LY, Haas ST-30LY, Haas ST-35LY, Haas ST-20SS, Haas ST-20SSY, Haas ST-30SS, Haas ST-30SSY
Changed Chip Breaking cycle to use IJK attributes in Haas mill turn post processors.
Mazak Integrex i-100, Mazak Integrex i-100s, Mazak Integrex i-200, Mazak Integrex i-200s, Mazak Integrex i-300, Mazak Integrex i-300s, Mazak Integrex i-400, Mazak Integrex i-400s
-Changed counter boring cycle to use G82 and added support for guided deep drilling in the Mazak Integrex post processors.
-Fixed Deep Drilling cycle to use expanded cycles when pecking depth reduction is required in the Mazak mill-turn post processors.
EZ 8M, EZ 8MY, EX 8MSY, EZ 10M, EZ 10MY, EX 10MSY, EZ 12M, EZ 12MY, EX 12MSY, QTU 200-M, QTU 200-MS, QTU 200-MY, QTU 200-MSY, QTU 250-M, QTU 250-MS, QTU 250-MY, QTU 250-MSY, QTU 350-M, QTU 350-MS, QTU 350-MY, QTU 350-MSY, Quick Turn 100-M, Quick Turn 100-MS, Quick Turn 100-MY, Quick Turn 100-MSY, Quick Turn 200-M, Quick Turn 200-MS, Quick Turn 200-MY, Quick Turn 200-MSY, Quick Turn 250-M, Quick Turn 250-MS, Quick Turn 250-MY, Quick Turn 250-MSY, Quick Turn 350-M, Quick Turn 350-MY, Quick Turn 350-MSY, Quick Turn 400-M, Quick Turn 450-M, Quick Turn 450-MY
2. New Machines
The Machine Library lets you manage your machine tools by using Machine Configurations to define your available machines and resources. These configurations can automate the settings in your Job Setup.
There are many Machine Configurations available in the standard library.
Milling Machines
You will have available configuration files for some of the leading machine manufacturers:
SPEEDIO S700Xd2
Ares 4818
Poseidon 26/60 KX5
145M12
KX 200
The easiest way to get started, is to copy an existing configuration that matches some of the characteristics of your machine.
Additive Machines
Prusa MK3.9
Milling Machines
UMC-750
Additive Machines
Bambu Lab P1P, Bambu Lab P1S,
Bambu Lab X1, Bambu Lab X1C, Bambu Lab X1E
HP Metal Jet S100_thumbnail.pngHP Metal Jet S100
Trumpf TruPrint 5000
Mars 4 -Generic- 50 micron, Mars 4 Dlp -Generic- 50 micron, Mars 4 Max -Generic- 50 micron, Mars 4 Ultra -Generic- 50 micron, Mars 5 -Generic- 50 micron, Mars 5 Ultra -Generic- 50 micron, Saturn 3 -Generic- 50 micron, Saturn 3 Ultra -Generic- 50 micron, Saturn 4 -Generic- 50 micron, Saturn 4 Ultra -Generic- 50 micron
5. Improved Print Settings
ABS (Bowden Tube), ABS (Direct Drive), Braskem FL605R-CF, Braskem FL900PP-CF, CPE (Bowden Tube), CPE (Direct Drive), Nylon (Bowden Tube), Nylon (Direct Drive), PETG (Bowden Tube), PETG (Direct Drive), PLA (Bowden Tube), PLA (direct Drive), PVA (Bowden Tube), PVA (Direct Drive), TPU 95A (Direct Drive), Ultimaker Breakaway
Unified EOS Print Settings:
EOS P-0.06 mm,
EOS P-0.1 mm,
EOS P-0.12 mm
Renishaw RenAM400 Alluminium AlSi10Mg-0503-3177-Q
Renishaw RenAM400 Inconel In625-0502-3218-Q
Renishaw RenAM500Q Aluminium AlSi10Mg-0503-3177-Q
Renishaw RenAM500Q Inconel In625-0502-3218-Q
6. Documentation
Updated the Post Processor Training Guide to reflect the common content used in the milling posts and new features of the post engine.
Our development team is always working to update and fix the Autodesk CAM Post Processor engine. These modifications are not related to a specific postprocessor (as described above) but affect the entire library or at least the post processors using that specific class. The current post processor kernel is 5.245.
Updated the API help document to show details on user-defined properties.
You can find here all the information regarding the Autodesk CAM Post Processor engine.
To make our library more varied and complete, we are always working on new post processors. Some of them still need more testing before being released in the public library. Every new Beta post processor is announced in the Idea Station, you can find all of them in the Post Processor Idea Station.
Please note that if you choose to use one of these post processors, you assume all inherent risk in using it and we ask that you proceed with caution.
That being said, we are looking forward to get your feedback!
Click here to see the previous What’s New release.
Andrea Amilo
Senior Technical Consultant
Autodesk Knowledge Network | Fusion 360 Webinars | Autodesk Make
Replies (0)
