09:41 PM
Hello
I have been using F360 for sometime now and I have almost given up on getting good results with text. I just created a sample block to engrave sample text into the part.
When I try to engrave the text with a 1/16 spot drill the tool plunges to deep had give poor results. I just watched a tutorial on engrave function. The tutorial advised that the tool height would be adjusted in the Z so the tool would not plunge to deep and distort the text.
I really need to be able to engrave text on a cylinder by using my mills A axis. I don't even want to attempt that because I can't get any results on a flat part.
Can someone help ?
Sample attached
