Another cryptic error message..
crullier
crullier
I trying to program a pocket much bigger than the tool dia of 0.25.
I want to use a ball end because for aesthetic reasons I want cusps.  Either way, I am not sure why Fusion is not generating the path and I can't seem to understand where and why it's failing.
I can't post the file. =(
engineguy
@crullier
Under your "Passes" tab there is an option to Enable Cusps where it says "Allow Stepover Cusps", you don`t have this checked, have you tried checking that box ??
Stay Safe
Regards
Rob
engineguy
@crullier
Image of pocket with Cusps Allowed using a Ball nose, works fine, if the "Allow Stepover Cusps" is not checked I get the same error as you 🙂
Stay Safe
Regards
Rob
crullier
Thank you, that was it !!! (wow so simple , I "wasted" 20 mins no kidding, and some hair)
