Advice on Proper Operations for 3D Object
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I started a project and got some great modeling advice and help over in the other forum. My project can be downloaded from this thread.
My first thought are that this is going to be mounted on a flat shelf so the bottom side could just be flat to help simplify the setup. I've looked at the 2D Adaptive, Parallel, and Spiral operations and they all seem to do a good job in the simulation but I know that the machining time is going to be long before I see the final product so I'm hoping to try and get it at least close to right on the first try.
I've got multiple flat end mills and a 1/16" tapered ball-nose bit. I thought I'd start with a 1/4" flat end nose and leave some stock, then finish with the 1/16" ball-nose. Assumming that the correct plan of attack what operations would you use?
My next problem is how can I get the outline shape to be cutout? My thought is if I can get the shape that is viewed from the top to be cutout through the stock I can then manually sand the edges to soften it.
Any thoughts?
George
