- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a project that requires two different radius/roundover mills, 1/8" and 1/4". The bits I have are an Amana 56125 for the 1/8" (https://www.amanatool.com/56125-solid-carbide-point-cutting-roundover-1-8-radius-x-1-4-dia-x-5-16-x-...) and a Whiteside 1572 for the 1/4" (https://www.whitesiderouterbits.com/products/1572).
Within Fusion, the Amana tool library has their 1/8" bit set as a radius mill, which ends up properly rounding over the 1/8" fillet of the design. However, the Whiteside tool library has their 1/4" bit set as a form mill and the toolpath is too far from the actual edge/fillet of the design that it doesn't end up cutting or rounding over anything during the actual machining process.
How can I properly adjust, or manually add/enter, the Whiteside bit information to run as a radius mill to properly cut and roundover my 1/4" fillets? Thanks in advance!
