Additive manufacturing - moving around bar supports
b_grobelnik
b_grobelnik
I just started using the additive manufacturing extension in Fusion 360 and I find it really good. The only thing is that I can't manage to find an option that would enable me to move an already generated bar support.
Example:
I generate bar supports through out the object, now I would like to grab one end of a bar support and just drag it a bit to the left or right just to position it perfectly. How would I be able to do that?
seth.madore
I don't think this is currently possible
Seth Madore
b_grobelnik
Will this be available in the future ? I think this is an important feature to have. Thanks for the answer.
seth.madore
Unsure! I've reached out to the Additive Product Manager, will let you know what I hear 🙂
Seth Madore
seth.madore
Moveable supports are not possible in Fusion, confirmed with the Manager. NetFabb Premium can do that, so if you have access to it, that's what you should be using if you need the moveable supports.
Seth Madore
