Adaptive machining and look ahead
engineeringQCQFN
engineeringQCQFN
For 2.5D high speed machining, what look ahead should I be looking for?
in general 200 blocks ahead is enough for adaptative tool paths?
thanks!
jswickJ9PWC
Why not use as much as your machine can handle? Depending on your toolpath, tolerance settings, radius settings, 200 blocks can be more than enough or just barely enough.
engineeringQCQFN
Roughing:
0.15mm tolerance
0.15 smoothing
does that help? We still don't own the machine, just got a quote from Leadwell and the Fanuc comes with 200 block look ahead and optional is 400
