840 D post Processor home position before tool change.
jhayesWTCVT
jhayesWTCVT
Good afternoon,
I am looking for some help with my post processor my my machine Spinner U630 5 AXIS.
Before every Tool change i am after for the machine to return every axis to its home position X ais being the first then so on. Normally to do this on this machine you would use Cycle 800. But when i post the programs out this is not the case and the machine says can't do tool change as axis no in home position.
Could some one look into editing the 840D Post so for every tool change it uses cycle 800.
I look forward to your response.
a.laasW8M6T
Hi
Assuming you are using an up to date post you can edit this section
  retract: {
    methodXY     : undefined, // special condition, overwrite retract behavior per axis
    methodZ      : undefined, // special condition, overwrite retract behavior per axis
    useZeroValues: ["G28", "G30"], // enter property value id(s) for using "0" value instead of machineConfiguration axes home position values (ie G30 Z0)
    homeXY       : {onIndexing:false, onToolChange:false, onProgramEnd:{axes:[X, Y]}} // Specifies when the machine should be homed in X/Y. Sample: onIndexing:{axes:[X, Y], singleLine:false}
Where it says homeXY
Change to this for it to home XY on tool
  retract: {
    homeXY       : {onIndexing:false, onToolChange:{axes:[X, Y], singleLine:true}, onProgramEnd:{axes:[X, Y]}} // Specifies when the machine should be homed in X/Y. Sample: onIndexing:{axes:[X, Y], singleLine:false}
Making Single line "true" will home X then Y.
Z will already be retracted.
Andrew Laas
Senior Machinist, Scott Automation
jhayesWTCVT
Will this mark AXIs B and C return to home position as well ?
Thanks for the reply
a.laasW8M6T
No I dont think so
I'm not familiar with Siemens controls
Does the Cycle 800 do this for you?
I notice there are options for Cycle 800 in the post
Andrew Laas
jhayesWTCVT
Yes cycle 800 dose this but when using multi axis it dose post this out
