5 Axis Simultaneous Help
- Mute
- Permalink
- Report
I am fairly new to the 5 axis simultaneous stuff. I typically only use it when I can't get away with positional work. I've used the swarf tool to produce some chamfers where I otherwise would not have been able to. I am presented with a similar problem here. In the circled portions of the picture below you will see a 1/16" radius up against a vertical wall. I am not able to reach down and machine that from the top so I need to run a simultaneous path. I've been trying quite a few different things with the multi axis contour but it has so far yielded no results. I've tried various tool orientations (and no orientation). I can't seem to get it to produce anything. Any suggestions?
