thank you very much for sharing the post processor. 🙂 I tried to use it on my HY6040 but I have some understanding problems with it.
My machine is configurated in x,y,z and B rotates around x and A rotates around z.
For this I tried to edit the post processor:
I put the wcs at the intersection point of the A and B - axis. Because of this I thought I can neglect the pivotDistance and cAxisOffset. Is that right or for what are these distances?
I tried to test the 3+2 Axis function with the following part:
But if we look now to the g-code i noticed some problems:
The first planing operation should be correct because the block is 50 mm high and wcs is 14 mm away from the bottom so the z value should be 36, which it is:
But at the third operation - the pocket - there is a problem I guess. The block is 30 mm thick and the pocket is 1 mm deep, so the z value should be 14mm, or am I wrong? Here the z is 2.97 and that is to low I think.
With changing of the pivot distance the z value changes. So I think this error is pretty similar to the error @dan3s2020 had with his post processor. But I wasn't able to find a solution by myself.
I would be very thankful for any thoughts or help.
Best regards
David
